Hi All,
I am having some trouble with a named boundary being offset slighty when using the civil plan feature of the named boundary tool to produce sheet models.
As you can see. The clipped boundary gets offset slightly.This only seems to happen when using the alignment in the attached file.Previously this geomtry had a station equation attached. However, I have set to zero and the issue still remains.When creating a new alignment or using a new piece of geomtery, it works fine.
1488.Geometry.dgn
Has anyone experienced similar? If so, what was the solution?
Liam
Hey Liam,
Looks like you may need to adjust your sheet seed drawing boundary. Should just be a matter of going into it and changing its extents.
Mark
Thanks Mark. But that's not the issue. The sheet seed drawing boundary is siting correctly. As mentioned this only occurs with this alignment. Using another alignment or other OpenRoads geometry this does not occur. I know I can simply lay down some geometry adjacent to the alignment as a work-around. But I have seen this issue a few times now and am looking for a solution.
ok, have you regenerated the named boundary after removing the station equation?
Yes. Tried that also.
no idea, maybe just move your reference...
