Is there a way to attach a civil cell as a reference file and place it in the active file?....This would make better sense and would be easy to use. Then later you could move the cell to a library in your workspace or workset.
Hi joe, you can attach the DGNLib of your Civil Cells to a dgn but you want be able to use the Civil Cells properly, as they aren't supposed to work in this way.
Thanks Marc, it would have been nice though.............
Joe Lukovits
User Since TDP in the 80's,
Vax based Unix Workstations - Interpro32,
from the Intergraph Corp.
