I created an alignment from lines created in SS3 or SS2 - I copied in the lines, created a civil rule feature for those lines, and then created an alignment using Complex by Elements. Everything seems like it works great. I have my alignment, it's editable, and I can see the report. However - when I go to view the profile it creates a secondary line in the file. What is that line/alignment for? It is not something we want to have, how I can I eliminate it?
Is our workflow wrong with how we create the alignment?
Hello Megan,
The best practice would be to import the alignment from native software's using the .fil file for MX, or .gpk file for GeoPak or .alg file for InRoads You can import the geometry from these files using the "Import Geometry" tool from the "Geometry Tab > Import / Export". This will bring in the geometry as well as profile.
Hope this helps. Do let me know.
