When I select the button (bucket) "corridor objects", I can see all the objects in the corridor.
In some of the objects we can export/import the settings.
Is it possible to export and import all the corridor settings? So I can use that file as a template/input file and as a kind of a report to check all the values?
It would be great!!
thanks!
Hi Andre,
It is possible to export that information to the Design Input report but not import.
Sanders
Hi Sanders,
Thanks for your reply, knew about the design input reports (do you have a template which exports all the objects? now I use the roadwaysetup, but it don't export external references and clipping references).
But still looking for import/export all the corridor settings.:-)
