Hi, Sorry if this isn't the right place to write in.... I'm trying to get to grips with MXRoundabout and I've pretty much just started to use it.
Basically, I cannot see how you delete a Placed Roundabout (or even move one). Clear if you commit one its easy to delete it from the MX model but a roundabout placed but not committed just stays there. Under help there is a section on deleting an approach. It tells you to use the delete tool. Excuse me, MX, but where is this delete tool? :) The roundabout is not a CAD reference neither is it an MX string.
Thanks in advance for any help! Julian
Several ways to skin this particular cat, Using the 'Select Tool' you should notice that various roundabout components or the whole roundabout highlight. Once highlight is on the entire roundabout simply do a left click to select and then hit the delete key. Sometimes though it can be difficult to get the entire roundabout selected via this method, you can use the RHM to toggle between components or the entire roundabout or you can call up the element information panel (where you edit the place roundabouts component properties), select any component and the ‘Element Information' panel will give a tree structure for the selected roundabout, you can then select the top level object and delete.
Regards Ian
