In revit we can create a lot of parameters is there the same methodology in openroads designer
can you provide more detail? examples of exactly what you are looking for and where would you like these parameters? on the feature definitions?
we can file an enhancement request on your behalf.
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/177604/how-can-we-create-a-new-parameter-e-g-density-time-work-breakdown-structure-in-openroads-designer
when I open the properties in OpenRoads designer I could only see the existing features and properties ,what if i would like to add a new parameter to the properties like an example (time of placing this element(order), density of material and so on) or a special link(name) for a work breakdown structure WBS to link it to a management program such as MS project
Have you looked at attaching an Item Type.
You can create your own properties and then add the Item Type to an element.
Look at the Drawing Workflow, Content tab
THANKYOU SO MUCH, THAT WAS EXACTLY WHAT I WERE SEARCHING FOR
You're welcome
Glad to be able to help
