Transform alignments and terrain in ORD
As often as not, when designing a site, buildings move, get larger etc.
I have a site that I want to rotate 1 degree ccw form a point.  Is there an easy way to do this in ORD?  in SS2, I would create a preference and do it using transform.  My building outlines were all done using alignments, I offset to get the opposite sides and then made it into a complex and then ran a template around the outside.  My site has multiple buildings, plus the buildings are growing.  The growing buildings are no problem, moving and rotating the site is.
Do you have any suggestions as to an easy way to do this, rather than start over.  Relocating the original alignments that I used to create the buildings is not working.
I am using ORD 2018 release 3.
