my goal is to assign Items to Feature Definitions in DGNLib which are uploaded from Asset management.xlsm file. So in that case later when I create corridor I can set item properties from pick lists with connection to ...Lookup.xlsx. Everything works fine in DGNLib but in every other file which loads Feature Definitions from library it crashes at moment of creating corridor (assigning Item). I know it's still Technology preview but maybe someone have a solution. Maybe there is some variable which loads Asset Management.xlsm? I have knowledge only about variable for Lookup which, of course, I am using.
Krzysztof Jędrych
Hi Krzysztof,
i bought your boog for ORD, I tried to contact you before. Can I ask you for your *.xlsm file wih your asste as you have it for poland? i am crating something similar for our local purpose, so it can be helpfull if you will pravie me yours...
Thanks a lot
Jiří B.
