Does anyone else have also a problem with slope annotation on linear templates? Works fine on corridors but doesn't display on linear templates. I'm running update 6. Thanks.
Regards,Krzysztof
Krzysztof - I am running 2019 Release 1 (U7) and it is still the same. I will let you know when I have a reason why it does not work, and any workaround (if one exists). It may be working as designed (but not as you want it to).
Hi,May I know how do you do slope annotations in ORD?Thanks
Please view the following vodeo.
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/37274/video-side-slope-annotation
Hi Mark,
Is this a defect that will get fixed? We have long lengths of linear templates in some urban projects that we need to annotate earthworks.
Mark
Hi Mark,May I know are you able to annotate for slope benching using the same method?
