When I run a cut fill analysis on my corridor and OG file it will create mesh's ut they will not report back a volume because they do not appear as close. Any idea on how to close these and make them read an accurate volume?
HI Wyatt,
Is there any message displayed? Can you attach the dataset here to check the issue.
Hi Wyatt
We also have this issue, but have the following temporary fix until the tool is fixed:
- Create cut/fill meshes
- Under Drawing workflow -> Mesh -> Split Mesh tool (this breaks the meshes up where there are discontinuities)
- Re-apply the feature definition to the new split meshes
It's not ideal, but ti works for now.
Answer Verified By: Wyatt Martin
This still gives me a problem. I can see the mesh, it doesn't seem to close itself where we transition to a bridge. Is there other work arounds to force close a mesh?
Wyatt - What version of ORD are you running?
Version 10.04.00.48
