I am working on building out SUDA feature definitions. It was my intent to build two DGNLIBs for this effort, one for proposed and one for existing. The proposed utility DGNLIB is the SUDA seed file for hydraulic properties. In building the existing feature definitions, I created a utility project in the existing DGNLIB and then used the prototypes created with that in the existing Feature Definitions. When creating a network in a new (clean file) the nodes hold the prototype but the conduits do not. Has anyone seen similar, or been successful in using a secondary DGNLIB for conduit Feature Definitions?
Nodes are created properly, referencing the prototype assigned in the existing utility DGNLIB. Active File shows the prototype and allows changing, Library shows the assigned prototype, grayed out.
Conduits will not place giving the error below anytime an existing utility Feature Definition is selected, or you pass over a node with the Feature Definition in the Place Conduit dialog.
In the Explorer, conduits show that there are not any prototypes available.
Any thoughts appreciated.
Steve
Folks:
What I wound up doing here was to have a combined SUDA library for both existing and proposed structures, and used directories/ templates divided into a "Proposed" and "Existing" schema. Such allows us to utilize the SUDA seed file as Bentley has designed as a single library instance. It does make for a very large library, but it "seems" to work fine here (with the caveat that I may not be correct in the design for reasons which Mr. Garrett- in particular- may further explain); however, our cell libraries for Inlets, headwalls, valves, etc. are separated into Proposed and Existing libraries such that that they may be more easily refined. If any of you folks perceive an inherent danger in doing what I have done, please speak up! It is better to redesign a few things during development than to see a major flaw during design.
There are no technological risks to your plan. This whole area of conversation is just administrative challenges. If there is only one admin then having a single file is convenient for maintenance. But when the work load needs to be spread around then multiple files are handy. Where things become a real problem is when the administration of the files is dispersed to multiple groups within an organization which are only minimally connected to one another.
Example: an organization I know is only loosely connected between units of the organization. The utilities ggroup (think sanitary sewer) is very separate from the hydraulics unit (drainage design). Both groups maintain independent libraries yet both groups need hydraulic design capability, ie a single SUDA seed.
The solution is simple right? Just put the sanitary stuff into the hydraulic library which is my standard practice. But that solution assumes that one group will cede or share ownership of the library with the other group. See what I mean about being an admin problem rather than a tech problem.
Robert Garrett Senior Consultant
www.envisioncad.com
Robert:
Thank you so much (once again) for your thoughtful approach to this issue. The good news for us is that we are small enough not to have to deal much with the administrative challenges you have put forth. I have developed all which we have- so far- as regards ORD in situ. All CAD/ CADD/ software issues/ changes go through me as a single point of "knowledge" (LOL).As well, all of our libraries are also supported/ maintained by myself, and all information is at a common network location.
I do have- yet another- question for you, however: The program defaults to C:\ProgramData\Bentley\SUDA\10\ for the Conduit and Inlet Catalog (amongst other XML's). I have been trying to track down the configuration variable which points to this location such that I can store this information at a common network repository. Do you happen to know the name of this variable?
Thanks so much for your knowledge and your support within this community!
Have a great weekend!
Mark
Mark: Those XML files are mostly irrelevant, which is good because there is not config variable as far as I know.
Specifically for the conduit and inlet XML files you mention, these are not used in the day-to-day course of business. The catalogs which are consumed day by day are contained in the dgnlib file. The XMLs are really only useful in the OpenRoads/SUDA sense for a transport mechanism (export/import) between files.
So, why are they there? These XML files are part of the Haestad (OpenFlows) engine which are used in a much greater role when running Openflows products (StormCAD and the like) in a standalone configuration.
There are other XML files besides the catalogs, in the location you describe and elsewhere, which have a more active role day to day. In the queries and flex tables for example, you will see three categories 1) Project 2)Shared 3) predefined. The shared and predefined lists can be configured inside of the openroads environment but to roll them out to an organziation requires distributing the underlying XML. I have not found an elegant way of doing this, so I have always recommended store the organization standards in the SUDA seed under Project, ignore the Shared category and use the Predefined fr whatever they are worth.
Thank you so much in the information which you have provided here.
I have set up our SUDA dgnlib with the variable "SUDA_USE_HAESTAD_CONDUIT= 1". Such- I believe- forces the program to use the XML files rather than the predefined values when this variable is set to "0". I am assuming- now- that you have defined the variable to "0" and have modified the tables to use those- as would now be stored- in the dgnlib? I believe that I have made an inquiry to such in a previous post, but I would really like to better understand how YOU have your dgnlib set up. Better to learn from those who have gone before me in all of this development!
