I am running Openroads Designer Connect Edition 2019- Release 1. I need to edit a .rsc file, then import the line styles into a .dgnlib to be used in a Connect workspace. I open the .rsc file and am able to create the new base stroke pattern that I need. When I go to try and assign that base stroke pattern to my point , I get the dialog below. The dialog will not allow me to browse the stroking options that I have created. Thoughts on why this is? Thanks
Ryan:
I had noticed such as well with ORD 2019 R1 (although it may have been happening in other versions as well)... very annoying and quite impossible to make changes to linestyles. Perhaps there is an "upgrade" or "conversion" for the RSC's which I (we) do know about?
Thanks for the post, and hopefully we will hear something soon from the powers that be...
Mark
I have the same problem. How are we suppose to edit linestyles? I guess everyone should keep a copy of Microstation SS4 available.
installing release 2 seemed to solve the issue
One potential solution to this issue is to follow the steps from the video in the link below to rename/delete the prefs folder. One user specifically deleted the Personal.upf from that prefs folder, and that fixed the issue.https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/52758/video-deleting-user-prefs-and-temp-foldersRegards,Jacob
