Is anybody else having problems with ORD not launching now that they have Windows 10 1809 installed? We have tried old versions, new versions, wiping every folder and registry entry for ORD, and nothing works. And we can't roll back Windows 10.
Any ideas?
Thanks,Chris
What version of ORD are you running, Chris (I am assuming based upon your narrative that you have installed ORD 2019 R1 and have tried it out?).
Mark
We have tried ORD Connect U3, ORD Connect U6, and ORD 2019 R1. None of them work.
To be clear. They launch but hang at the splash/start screen forever.
Yes. This is a known problem, which I also experienced some time ago. Win 1809 and ORD do not get along. It's not just ORD, apparently there are many other applications affected as well. It is so bad that there have been unconfirmed reports and suspicions that MS will withdraw 1809. I think your only hope is rollback windows or tough it out until MS releases their next update. (Note clarifications in my posts below)
Robert Garrett Senior Consultant
www.envisioncad.com
Well as I said we can't roll back. Windows won't let you do that after 10 days.And we can't just "tough it out" since we have deliverables.We can't be the only people in this boat. What have other firms done?
I installed ORD yesterday,it has the same problem with you,then I deleted all the files which are related to Bentley,finally,it worked.
