I am using Concept Station 10.00.10.17
I have a model where I am showing 3 tiers. I want to show/model retaining wall after the bridge abutment. But it is day lighting to the ground!
I dont see any option in the templates for wall?
Is it something I'm missing or the software is?
Can you not create a template for the wall yourself?
MaryB
You will need to create templates for either cut or fill retaining walls. They cannot be combined. It this what you are wanting to accomplish?
Hope this helps. Thomas
Thank you Thomas.
I just did what you gave a solution for and it worked.
Thank you,
Abhiram
Yeah. That's true Mary. I had to create my own customized template.
I thought Bentley is giving it all ;)
