I'm creating terrain models from elements by selecting individual feature types (breaklines, spots, voids) and adding them. When adding the spot features, the individual point elements are all deleted from the .dgn. They still seem to be occupying the level, but they are no longer visible. This is happening in Power InRoads, Power Geopak, and Open Roads Designer on both Windows 7 and Windows 10 systems.
Is this a setting that can be changed? Or is it by design? If so, what is the purpose of deleting the elements?
Jason
I'll look into this for you.
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
Jason,
I've having trouble replicating this issue with success. Can you detail your workflow and/or possibly send the dgn?
Spot Features .dgn
Here's the ORD dgn I tested with.
Was this ever resolved? 2022 ORD 10.10 and still having the same problem...
Same issue here also. Anytime i create a terrain model now, when i add spot features, the survey points disappear from the drawing. I found that when i add any points to a terrain model, in the survey details the display setting is set to false. If i set it back to true the points come back.
