Is this possible in the 10.7 version of ORD?
In ss4 you could section over a line string that had angle points in it. Is that possible in ORD. would like to create drive sections that are perpendicular to the road out to the EP and then skew.
Hi Mark,
Is there a way to cut sections by graphic (a line string with multiple points)?
I also noticed that it will place each section cut in separate drawing seeds when cutting section by 2 points. Is there a way to get a list of skewed angle stations, then cut, like how we did on Inroads? I looked into adding event points but it only cut the sections perpendicular to the alignment.
Did you ever find a solution for this?
I provided a response to something similiar in..... Annotating Civil Cells in cross sections in OpenRoads Designer Connect Edition - OpenRoads | OpenSite Forum - OpenRoads | OpenSite - Bentley Communities down near the bottom.
basically add\cut a section at the drive location, and reference in a drive way profile drawing model that was created at the same scale as the sections. the cross section information can be clipped out leaving just the information from the drive profile.
Hi Marc, and can we generate at intervals the skewed cross section? I used the tool but it only generates one cross sections. However I have my corridor with skew and I need to create the cross sections.
