Hi
In ORD 2019 R1, how does one split up the cut and fill quantity reported for a layerwork component? i.e. the amount of material that has to be cut in order to place a component and how much of the component is in fill.
Pre-OpenRoads GEOPAK was able to do this, but I can't find out how to do it in OpenRoads/ OpenRoads Designer.
For example, in the figure below, I would like to know the volume of the component highlighted in light blue and the volume of the component highlighted in yellow.
Hi Warren,
I created an enhancement for development to add this report to ORD. Number 1024886.
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
Warren,
This functionality was actually made available in ORD 2019 R1 and beyond. When you run the OpenRoads Modeling > Home > Model Analysis and Reporting > Civil Analysis > Create Cut Fill Volumes tool you are given the option to check "Compute Custom":
To implement this here is what you need to do.
Hi Holly,
Thanks for following up! This is great news!
I'll test it out.
