I've just watched the below video on how to place multiple cross sections on one sheet:
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/37324/video-create-multiple-cross-sections-in-one-sheet-model-in-openroads-designer
However, when I follow the same workflow the following happens:
Multiple cross sections models are referenced into the sheet model but for some reason only one is visible.
Anyone know what's going on here?
File attached.
Joshtest80.zip
That is interesting, I have not seen that before. Have you tried to use the delivered cross section seeds? Is this a seed file that you created?
Hi Marc,
No I haven't tried the delivered cross section see and yes this is a seed I created myself..
Do you want to see the seed files?
I would open one of the Bentley delivered seed files and see exactly how they set it up and try to match that. I would also try to use a Bentley delivered seed file in the same workspace you are in to determine if it is in fact the seed file or something else at play.
Ok Marc, I'll have to look into that
