[ORD U7] Can non-template strings\surfaces by automatically annotated in ORD?
Hi All,
When creating X-sections through ORD, any points created from a template within the x-section area are annotated according to the rules in the annotation group. However, I have found that if I have any non-template (but still featurized) strings\surfaces within the X-section area they can not be automatically annotated.
Is this working as designed? Are we expected to annotate all non-template points manually? This is not ideal through areas that reqiure a lot of manual string modelling such as intersections.
Liam
