Hi All,
When creating X-sections through ORD, any points created from a template within the x-section area are annotated according to the rules in the annotation group. However, I have found that if I have any non-template (but still featurized) strings\surfaces within the X-section area they can not be automatically annotated.
Is this working as designed? Are we expected to annotate all non-template points manually? This is not ideal through areas that reqiure a lot of manual string modelling such as intersections.
Liam
I just did. thanks.
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/202729/annotating-cross-section-slopes-in-openroads-designer-version-10-08-01-33
