Has a change been made to editing Text Favourites?
Creating seems to be the same but I am unable to edit them.
Josh
Any help on this?
I need to interrogate Bentley delivered text favourites to see what fields are assigned to them so I know what to assign to my custom favourites.
Are you using the Text Favorite Manager to look at the details?
Hi Mark,
I am trying to find the text favourite manager. It's been a while since I worked through this workflow but from memory I thought there was an option to open the manager from the bottom of the text favourite list, I am not seeing it.
I also thought you could edit favourites by double clicking on them, when I do i see this error message:
I want to know what text favourite field is assigned so that the correct chainage shows up on each cross sections, currently with my testing I have had no success.
It should read Chainage = 50.000, not sure where it's getting 1420000.000.
What version are you running at the moment? The Text Manager is a 'Tech Preview' piece of functionality, and has a timeout period (which may be what is happening here).
I am running OpenRoads Designer CONNECT Edition - 2018 Release 4 Update 6 - Version 10.06.00.38
