SUE Library - Geopak Drainage Nodes/Conduits
I want to use the Geopak TXDOT drainage library (e.g: storm nodes/conduits) in OpenRoads SS4 (SUE). I went through this post - Bentley Communities.and followed the steps.
The XML exported from there, I got to import in SUE, which came up in the engineering library.
But, when I'm placing the node or conduit, the feature definition seen is only "Generic"!
How to bring this imported XML library, which is seen under the engineering library ?
(Earlier I had not activated the SUE license, but later I activated successfully, and then did it again in the same dgn. I hope this is not the issue!)
