I have a PC with the 8.11.09.832 version of MicroStation. I followed the instructions in the Wiki articles to get this installed.However, I still get the wrong version message when trying to install InRoads SS4 (8.11.09.878) -
Is this a MicroStation problem or an InRoads problem?
Tom F.
I double checked the readme and it does say MS .832 as a requirement BUT i don't believe it would be the first time a document has not been kept up to date. We have IR .878 installed with MS .867 without any problems.
Those versions are compatible. Are there any other versions of MicroStation on the cpu? I would recommend a clean uninstall/reinstall of MicroStation .832. Then attempt to install InRoads.
MicroStation Clean Uninstall
https://communities.bentley.com/products/road___site_design/w/
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
Marcus,
Tried everything in the list, InRoads 8.11.09.878 will still not install - still gives me the "Supported version of MicroStation" message.Anyting else you can think of? At this point we're getting close to re-imaging the PC for the amount of time we've spent installing and uninstalling all the various versions.Thanks,
I fear you need to remove the microstation from the registry. I don't remember the whole thing but you might be able to search for Bentley. Use the command line regedit. Be careful though.
You might try clean uninstall and then run a registry cleaner.
