I incorrectly use the wrong number when setting up the workset for a recent project. Is there a way to correct this without creating a new workset definition.
Thomas,
The default location of the Workspaces and subfolder(s) Worksets is C:\ProgramData\Bentley\OpenRoads Designer CE\Configuration\WorkSpaces. Look for your workset name (myworkset.cfg) you can change it through file explorer. You will also need to change the workset folder name to match the workset cfg. If your not using the default workspace, you can check the config variable _USTN_WORKSETSROOT
Next time, include the version #, answers may change depending on the software version.
Tom F.
