As a part of my project requirement am in process of transiting my select version model dgn's to Connect version (ORD).
For now the process which i followed is as shown in below link which converts the version of the dgn/model and dgn's are working fine for now.
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/41243/video-upgrading-dgn-files-containing-obsolete-civil-data-for-use-in-openroads-openrail-designer
The issue now am facing is, the feature definitions which i created for using in select version models cant be seen in ORD. Can someone suggest me how to call on all the feature definitions which i created while using the select version for my dgn's into ORD please ?
And, is there any way out to use the select series Templates into the ORD directly, or will i need to recreate all the templates into ORD from scratch.???
Thanks for the any help which you can give on this.
I believe what you are seeing/asking is related to this inquiry from a few months back. It is a defect we logged when moving data up from SS4 to ORD.
Defect 919130.
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/154539/ord-upgrade-of-ss4-data---no-feature-definitions
For the templates, you can use the same ITL, but when moving forward we now use Feature Definitions instead of Styles for the components/point and there may need to be some conversions done. Here is a link to the latest Migration Utilities which includes a utility for Template Library ITL Converter.
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/41342/migration-utilities
Hi Chris,
Thanks for the reply.
I sorted out with getting the SS4 OR .ITL file to ORD.
But what i feel is, until we get feature definitions sorted out from Bentley side in next release we cant able to see the templates in exact/perfect. Basically without feature definitions all my templates are greyed out(Image attached)
Correct me if am wrong please!!.
Thanks in advance.
