I am having a few problems figuring things out.
I am having problems viewing any cross sections through my corridor.
Also, I have a template created for the corridor where the left end conditions are not showing up as part of the model, but the daylights do.
I have checked the template and compared the left and right and am unable to determine what the problem is.
Does anyone have some ideas why this is happening?
Below is the 3D view and the 2D view with 3D mesh showing.
Dee,
For your second issue, I have seen similar issues when "Use Feature Name Override" is used on both sides and does not have unique names left and right. I would start by confirming that the name override is either off, or uses different names (_RT and _LT after what is there or something similar).
Can you provide a little more information on what you are trying to do in viewing sections and what issues you encounter?
Steve
www.envisioncad.com
ORD - 10.12.02.04 / 10.10.21.04 / 10.10.01.03 / 10.08.01.33Power GEOPAK / Power InRoads - 08.11.09.918Civil 3D - 2021 / 2022 / 2024
This is usually the terrain being off in the 3dModel. Anything and everything in the 3dModel shows in the xsections. This includes structures like pipes and headwalls if they are solids.
