My profiles have disappeared from my drawing. I am working in ORD 2019 rel 1. I created profiles successfully using the Named Boundary command. The drawing model and sheet model looked good at first. When I restarted my computer the next day and opened the profile drawing, my profiles were missing. The drawing model still has the annotation for the profile, but my existing ground and proposed grade linework is gone. From the drawing model the reference for the profile says "Model not found - (AttachedLongSection)". I don't have the option to Reload the reference. I created a new profile successfully. I restarted my computer twice. The profile linework disappeared again. Does anyone have an idea what is happening?
Hi Dalek
Did you find a solution to your problem? I'm having the same issue.
I have seen this same behavior as well.
A couple of questions:
Hope this helps.
Marc
I believe my problem was due to having 2 WorkSpaceSetup.cfg files. One was local and the other was on the network drive. I removed the local WorkSpaceSetup.cfg and used my network version. My profiles have worked successfully since the change.
You might want to try loading the Bentley delivered WorkSpace & WorkSet. If they work without error then you have something wrong in your custom WorkSpace or WorkSet.
Marc B,
Compress on exit is disabled. I keep both horizontal & vertical geometry in the same DGN file.
Dale
Civil 3D 2018, ORD 2019 Rel 1, InRoads SS3
Drug kicking and screaming into the world of InRoads & ORD!!
I think this might be the cause - the one user who has been experiencing this problem has a PowerDraft and an OpenRoads Designer WorkSpace.
