[OR Ss4] Survey Coding TMPL - Gone Rogue
I'm working with a TDS RW5 file, originally coded for InRoads Survey. It is a sample file used for training. It uses a number of TMPL codes, most of which work as expected. But this one that was a top of curb, bottom of curb and gutter edge was doing something unexpected. The master figure is create with a code of BC ST PC TMPL and the two parallel figures are started with TC ST PC and EPR ST PC.
So what is the problem? THis is what it looks like on screen with all three figures selected. Notice the locations of the two offset figures compared to their Manipulators locations. And, if I change the code on the master figure to an ST, they suddenly draw correctly but are no longer curved figures. Adding a ArcSingle to the middle point to try an reintroduce the curved figure results in the figure resetting it back to the bogus offsets. And changing the ST PC to an ST on either parallel figure starting point completely removes the figure from the file, renumbering similar figures in the process.
So far, the other TMPL codes in the file seem OK.
Apparently, I spoke too soon. I've found a few others where no parallel figures are created and no amount of edits seems to change anything. If I had to make a recommendation, I'd probably recommend not using the TMPL code.
