I can't figure this out - How do I start a macro in ORD - I have my macro auto loaded in the VBA Manager
The only way I can get it to play is to open the vba in the editor and hit play from there - there has to be an easier way.
I don't want all of my users going thru the editor to start playing the macros
I can see other auto loaded vba files in a pull down on the macro ribbon - why does my vba macro not show up in the list if it is auto loaded?
Thanks for the Help
This may be a part of the issue which you are seeing (and which applies to all Connect Edition products):
https://communities.bentley.com/products/programming/f/developers-and-programming-forum/132973/trying-to-use-microstation-v8i-macro-ba-and-run-in-microstation-connect-macro-unsuccessful
Hi Dan,
You can run a vba macro using a keyin:
https://communities.bentley.com/products/microstation/w/microstation__wiki/21821/running-a-vba-routine-by-keyin
You can add this keyin to a ribbon or menu button as well.
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Mark - Thanks but I was looking for a easier way to run my MVBA files
Dan
PowerGEOPAK SS10 and ORD
I thought of that but I have not gotten into the ribbon / interface modifications yet and I don't have the time right now to dig into it
I was hoping that it was something I was missing on the dialog that I could pass on to our other users - In my opinion Bentley could have improved the dialog over the Select Series dialogs but went backwards
