Hello
is it possible to import customized templates in openroads designer into concept station. if there isnt then i think Bentley should look into that work flow. I have customized a template i.e an open concrete u channel in openroads designer that i want to export to concept station. Template editing in concept station doesnt give that flexibility yet. any help please
Hi Daniel,
Let me get back to you on this one soon
regards
No you can't.
OpenRoads Designer is for detailed design with more advanced functions than ConceptStation. ConceptStation intent is to be easy and fast. It does often mean less capabilities. We have to balance between capabilities and easiness. However, it could be interesting to be able to import read only templates in ConceptStation. But it also means that processing engine should be able to deal with all complex end conditions we are able to create with Designer.
