Has anyone else had issues creating a Clipped Terrain using a boundary that has some steps in it - I was getting "Error calculating Terrain" error messages, until I removed a few abrupt steps in the boundary shape elements shown below. Out of a perimeter of 14260m, with many many alternating shapes, these 3 were the only causing problems:
Mark
I have not seen this problem. If you send in the dataset I'll have a look at it.
https://bentley.sharefile.com/r-rd155cde225f40628
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
I've had the same issue with steps that are 100% perpendicular. 90 degrees won't calculate, but 89.99999999 does.
Unfortunately I can't locate the data set that demonstrated the issue, maybe Warren has one?
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
