Openroads Tips - Deleting corrupted mesh from corridor
Took me some time to find this: how do you delete corrupted old mesh from corridor?  Before we could use the "civil display browser" but now we can't
In the example below I have 3 curb mesh that I can't delete because they are still "associated" with my corridor, but of course do not follow it anymore…
1: use the delete Mesh Facet command
2: select the mesh and use the line to cut through it to delete part of it
3 - now use the "convert mesh to surface" tool
And you are done! The software just deleted the corrupted mesh.
Also if you have corrupted lines:
1- turn them into mesh, then delete them
Clearly it's dangerous to have mesh with feature definition laying around in "double"
