Volume of proposed Model to Ex terrain SS4 (08.11.09.897)
Simple question but I created a model of a berm that will be used to store excavation. I created the outline of the bottom of the berm which is draped on ex ground then I attached a linear template made of an end condition that seeks an elevation of 924. After adding the linear template, I then created a terrain model by choosing the bottom outline and then the top outline (which was created by the linear template) which is at elev 924. Everything worked but I am now trying to get a volume of the berm in relation to the ex terrain but I can't figure out how to calculate it. The image of my berm is below. Is the problem because I do not have a "cap" on the top? What tool do you use?
Parents Reply Children
