Hi All
When trying to operate the SUE functions within the programme, I'm getting the following warning message;
Would anyone be able to advise the issue and solution please?
Kind Regards
Jamie
What version of OpenRoads Designer are you using, and what WorkSpace? What is the value of the SUDA_SEED_FILE variable? The file pointed to by this variable should contain a default SUDA database.
Hi Mark,
I'm using the Openroads Designer Connect Edition 10.07.00.06
The workspace being used is below;
How do I find?
Mark Marnell said:the value of the SUDA_SEED_FILE variable
File > Settings > Configuration > Configuration Variables. Type 'suda' in the search bar at the top to make it easier.
Mark
This is what is coming up in the settings;
That file is the same as what I point to (855kb file size). What function beings up that message?
