I have imported multiple parcels into OpenRoads from an InRoads ALG. It has imported them all as not featurized. Is there a way to select all these Linear Geometry elements and assign them the same feature definitions. Currenlty I'm having to select them one at a time and change them.
Thank you, Corey
Try the set feature definition command. See snippet below from the help menu. It supports selection sets also so you can add all the imported elements to a set and try this workflow.
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/180875/openroads---2019r1u7---is-there-a-way-to-assign-a-feature-definition-to-multiple-linear-geomtry-elements-at-one-time
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
Answer Verified By: Corey Baird
