Is there the automatic catchment delineation tool in openroads?
Thank you in advance.
In the latest version, there is auto-catchment feature in Subsurface Utilities.
You access the feature when you place a storm water catch basin, and you pick a terrain model as the reference element for elevations. we need the terrain model as the surface to run the delineation on. See the following SIG:
https://learn.bentley.com/app/Public/ViewLearningPathWithMasterCourseExpanded?lpId=111750&mcId=102713
2019-03 (March) OpenRoads Subsurface Utility SIG - What’s New in Subsurface Utility Design and Analysis
Answer Verified By: Sotiria Kalaitzidou
Is there any way to change settings of catchment delineation in Openroads Designer like Openflows? Thanks in advance.
I have been told that this dialog will be in the 2019 Release 3 version of OpenRoads Designer.
Thanks a lot.
Can the automatic catchment delineation be turned off? I have an existing inlet placed and do not want the catchment updated when I rotate or change the inlet type.
