Is there the automatic catchment delineation tool in openroads?
Thank you in advance.
I couldn't find the "Catchment delineation options" in ORD 2020R1. Is that dialog added somewhere in the application?
This dialog can be found at Drainage and Utilities>Tools>Project Tools>Catchment Delineation Settings.
Karl Dauber, PEAdvance ConsultingLaurens County, SCkarldauber@advconsult.netwww.advconsult.netwww.linkedin.com/in/karldauber
I have not tried it, but if the feature definition is using it, then I would say no.
Hi There,
Does anyone happen to know if there is a way to add in the automatic catchment delineations "After" a network has been placed. Or, would you have to delete everything and then place al the nodes again with the toggle turned on?
Thanks in advance!
No - you cannot add the auto catchment after the networks has been placed.
