I am experiencing challenges with "Place Horizontal Temporary Dimension" and "Place Vertical Temporary Dimension" in the cross section view. I can activate the commands but upon the prompt to "Select Cross Section View" I cannot get OpenSite/OpenRoads to recognize the view regardless of where I click in the cross section view.
Does anyone have experience resolving this issue?
Thank you.
Jeremy:
Yeah, it is buggy, heh? If I use the right-click option, I get nothing. If I use it from the menu MOST of the time it works; sometimes it does not.
Mark
Thanks Mark, I have tried both and am experiencing failure with both methods. It was working last week and I have tried to figure out what setting I may have changed to cause it not to work today.
Are you seeing a "Template Drop not found" error in the message centre? Dynamic Cross Section measurement needs an overhaul, looks nice but what info can you get from it (when it works)?
OpenRoads Designer 2022 R3 (10.12) | Microstation 2023.1 | ProjectWise CE 3.4
I am surprised that you had it working with both methods. The right-click has never worked for me.
Bentley folks: please let us know what is happening here?
Mark:
Thanks for the input, but "Template Drop Not Found" was/ is certainly not an issue of mine in particular, and I agree that the temporary measurement tools are kinda' gimmicky. Usually, I just cut some actual cross sections in an area of need and take measurements the "old fashioned" way.
