set maximum number of cross sections per sheet
I am trying to set up cross section sheets in ORD. I am able to create my sheets and the cross sections plot correctly. Now I want to limit the cross sections to only 2 per sheet. I cannot find a setting that will limit the number of sections per sheet. Is this possible or do I have to select the named boundaries 2 at a time when creating the sheets?
