To avoid creating one myself, is there a UK highways template library available for download?
Josh
The standards cross sections are in the UK Country Kit template library. The roads construction layers would need to be amended depending on project etc.
There is a UK dataset available on the Bentley fulfilment centre, sorry i don't have the link.
There are some templates for the DMRB in the template library, but the rest of the dataset is severely lacking. No IAN184 feature definitions, no civil cells for roundabouts to TD16 or Junctions to TD42. Standards file and superelevation rules don't work properly. However the last time i looked at the dataset was last year, hopefully there has been some development on this front since.
Any chance you could send me the .itl file Mark?
There is no IAN184 feature definitions - as no-one can agree on a common 'standard'. There is an example DGNLIB that gives the levels defined in IAN184 if you wanted to include it. (Additional note - IAN 184 is being rewritten.)
Civil cells are not suitable for roundabouts if they are to be designed using the Stockdale method - if you are talking a simple mini-roundabout, a civil cell may be suitable.
What standards file did not work, and what was the issue with superelevation? Have you logged the issues as Service Requests?
The ITL is attached.
[Hopefully you know the latest ORD version is 2019 Release 1 (10.07), and you have it installed.]
CivilTemplatesUK.zip
Answer Verified By: Josh WHEALY
Thanks Mark
