I am using a linear template to place a footpath and was hoping that after assigning a point control my BOF geometry everything would be fine. It would appear that the level of detail of the template drop is not high enough because instead of following the arcs in the BOF geometry, it's creating straight lines. Currently the level of detail feature definition is set to final but is still not good enough. Pink is template BOF and turquoise is BOF geometry.
I've never had this problem before, does anyone know what's going on?
File attached.
Josh
BOF Template Detail.zip
HI Josh, I opened the file 'North of Terminus Ramp BOF Template.dgn', there are some Linear Templates but none of them contain any Template Drops. If I open 'Terminus Template.dgn' none of the Linear Template are related to this BOF. Can you give me more information and let me know which is Linear Template?
