Open Roads Designer - Deleting "Ghost" Conduits / Elements from Design File; Prevents Hydraulic Analysis
Hi. I’m hoping someone else has some experience with this in Open Roads Designer Connect Edition.
There are some “ghost” elements in a file that is preventing me from running hydraulic analysis.  If I run a "validate" or "compute" I end up It says that there is 2 conduits/elements with error message 440256 that I cannot select to delete.  The file did contain a handful of additional conduits and structures which were deleted, I believe this is data remaining from those.  The only location where I see these elements and know they exist are the flex tables and the user notification errors. They cannot be deleted from either location.
I have tried the following:
- Looked through the Explorer to try to find these. They are not available.
- Deleting all attributes in the flex table for these elements in an effort they are removed without info. Or the analysis would run.
- Synchronize Drawing. They following error appears when they prompt to pull missing info back into the drawing appears.
Does anyone have any other ideas on how I can select these two "ghost" elements so they can be deleted from the design file?
Any ideas help, Thanks!
Parents Reply Children
