ORD import terrain breaklines form text file
Hi all
I am struggling with setting up import text file parameters for a file that contains breaklines. The breaklines are formated in the way that the points belonging to a beakline are separated between lines START and END. Than each line is composed with X Y Z separated by a space. I am not getting any results ie import is successful but no lines created nor the terrain model.
Start
389315.70 639222.42 194.20
389306.68 639310.05 193.89
389301.92 639358.50 193.55
389303.02 639367.38 193.38
389298.73 639408.97 193.21
389291.78 639463.40 193.38
389283.19 639536.03 193.55
389275.41 639590.54 193.05
389268.29 639647.29 192.88
389263.05 639698.88 193.05
389257.53 639748.12 193.55
389254.16 639776.38 194.17
389247.57 639818.38 193.83
389240.31 639875.59 194.68
End
  • Benedykt
    As a workaround, you could import the coordinates into a DGN, and then add the elements to the terrain model as breaklines. The VBA routine below will import your data. NOTES: (1) there is no error checking (2) the SmartLines are created on the current level with current symbology (3) this is just an example and the code is unsupported
    Sub CreateSmartLinesFromFile()
    Const ForReading = 1
    ' Sample data from which SmartLine is created
    'Start
    '389315.70 639222.42 194.20
    '389306.68 639310.05 193.89
    '389240.31 639875.59 194.68
    'End
       'Add Microsoft Scripting Runtime ( Tools>References ) to use FileSystemObject
       Dim fso As New FileSystemObject
       Dim sourceFile As TextStream
       Dim strLine As String
       'Dim lCount As Long
       '*** NOTE: the text file is hard coded on the next line ***
        Set sourceFile = fso.OpenTextFile("D:\Test.txt", ForReading)
        While Not sourceFile.AtEndOfStream
            strLine = sourceFile.ReadLine
            Select Case UCase(strLine)
             Case "START"
                'lCount = lCount + 1
                'Debug.Print "Count = " & CStr(lCount)
                CadInputQueue.SendCommand "PLACE SMARTLINE"
             Case "END"
                'Debug.Print "End"
                CadInputQueue.SendReset
                CommandState.StartDefaultCommand
             Case Else
                Dim tArr() As String
                Dim point As Point3d
                tArr = Split(strLine, " ")
                'Debug.Print "X=" & tArr(0) & " Y=" & tArr(1) & " Z=" & tArr(2)
                With point
                   .X = CDbl(tArr(0))
                   .Y = CDbl(tArr(1))
                   .Z = CDbl(tArr(2))
                End With
                CadInputQueue.SendDataPoint point, 1
           End Select
        Wend
        sourceFile.Close
    End Sub
  • Adding survey linking codes might be an option. That workflow would depend on the volume of edits in the ascii file your using as a dataset.
    Example edits below:
    389315.70 639222.42 194.20 start
    389240.31 639875.59 194.68 end
