Is it possible to import geometry from MX into ORD for further modeling? And how?
Can you import the inputfiles directly as in ss4, or a MX model, or as a .xml? genio?
Thank You
/Signe
You can use the import geometry from file tool. It wont run input files, but you can import the data from a GENIO or Model.fil.
Answer Verified By: Signe Helga vinge Hedegaard
