Dear All,
Greetings!
Is there any tool to export the Superelevation Data from OpenRoads Designer in Land XML format?
Also how to add the superelevation band in my profile view?
All helps will be appreciated..
Thanks in advance...
Hi Mark, with Superelevation Annotation defined as you suggest, when annotating model using such annotation group, the software shows Resolve Aliases for Definition dialog and only seem to allow selecting the superelevation lanes in the Target dropdown when the superelevation lanes are actually defined in the active drawing. If I try to do the same with superelevation information attached as an xref (either as separate file or as part of a corridor dgn) I cannot select anything from the Target dropdown. Can you please clarify?
Mariusz
OpenRoads Designer 2022 R1
I have just tried this in 10.07 - and I am reading superelevation from reference file without any issue. Started with blank file, referenced the terrain (1), corridor (2), and geometry (3 which contains the superelevation). [I normally have the super in the same file as the geometry as I feel they are a pair.]
No issues at all with selecting the superelevation. Are you still on 10.06?
Mark
Thanks Mark for your reply. I have tried from blank files as you said and it worked. I need to look closer why it didn't on existing files.
Thanks again,
