Hi
Whenever I make a new corridor, the corridor feature lines seem to end up on the default level I have on. I am working on projectwise and my workmates don't seem to have the same setting. They go on different levels depending on what component that feature line is set on. Kerb level for kerbs, carriageway level for carriageway, etc.
What setting should I be looking for to resolve this issue. I have tried reinstalling Powercivil and Projectwise but to no avail. I hoped by doing so it would take whatever setting it is in the workspace of Projectwise for a particular project.
I am using Powercivil for Denmark SS4
Thank you.
Do you have a managed workspace assigned to your project? That controls the configuration and you getting the right feature defs, element templates, template library, etc. Compare your workspace config to a computer that is working correctly and see if you notice differences?
Hi, yes I have checked those and everything seems to be the same. and then I stumbled upon that my Style Manager is empty even thou I have the right preferences loaded. And then I searched for that here and found this
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/31445/xin-is-blank---preferences-and-styles-lists-are-empty
Tried it out and it helped! :D Weird thou, because I'm using windows 7 and my other workmates are too and I'm the only one that needed to install the patch
