Is there a way to bring surface data from google earth into opensite?
if so how would i do it?
Are there any videos to watch over this?
With the old Microstation tools when you use "capture google earth image" it brings the image into 3D on a surface. I then make this surface into a terrain model with the terrain model tools. Its not the most accurate, but it works.
Here is a video I did on Google Earth and MicroStation. The capture google earth image is at the 5:39 mark.
https://youtu.be/7I5b9Mwxq7g
Hope this helps,
Bob Mecham
