Ditch Slope
I am running my proposed cross sections with special ditches in geopak. In my criteria files, I specify the foreslope and backslope of my special ditches, but whenever I run the cross sections, the line connecting the shoulder to the subgrade slope doesn't match the slopes I want for my special ditches. The only way I can get this right is if I change the values in the define variables tab by modifying the "left ditch slope" and "right ditch slope" but I have several special ditches with different slopes. Is there a way to fix this in the criteria file? I've tried using alternate side slope code in the criteria file with the special ditch but it still doesn't want to keep the special ditch slopes.
