I have my survey data file(.dwg) . I want to show (display) the latitude and longitude (in degree, minutes, seconds) of each point.
If anyone can suggest anything....
Vaibhav,
To work with Lat\Long you need to have a geographic coordinate system attached. You won't be able to do that if the file is an dwg so first save to dgn.
Tom F.
Tom,
thank you very much for the timely guidance.I went to ACS but I could not set Lat/Long (in degree,min,sec). A snapshot is herewith attached.
Look for the coordinates in the lower right, left click on them and select ACS Position.
Also, your coordinate system needs to be active - If Military Grid WGS84 is correct, fine. If you want to use UTM84-44N then you'll need to double click on it and make it active.Tom F.
Thanks Tom,
The Northing-Easting coordinates are visible in Latitude-Longitude (degree, minute and second).
My next requirement is that I want all the points in the .dgn file to be highlighted with text as (Latitude1,Longitude1),(Latitude2,Longitude2)….
Try this VBA:
https://communities.bentley.com/products/geospatial/desktop/w/geospatial_desktop__wiki/6580/--label-latitude-and-longitudes-vba
It worked for me in v8i SS4, but not CONNECT (it's very clear about that)
