[IR SS2] Generate H & V geometry from point elements?
I have received several files from our surveyors that have any number of points drawn into them. These are not COGO points. They are spot elevation points shot along the centerline of a road. They are graphic cell elements, more or less in a line, that I need to generate horizontal and (corresponding) vertical geometry from.
i have no idea how to turn this collection of spots into an alignment, let alone how to get that alignment to read and generate its own vertical geometry from the spot point elevations.
Can this be done strictly from elements? Do I need to request the FWD file (If so, what do I do with it)?
I know I can import the symbols to be COGO points, but that isn't getting me any closer to a solution.
Chain Points looks promising, but that wants me to physically click from point to point to point to point...
Create Alignment from COGO points looks promising also, but it doesn't do what I think it does.
Curve fitting looks interesting, but that appears to be more for refining AFTER I've chained the points together.
Any suggestions or guidance?
Thank you.
MaryB
Power InRoads 08.11.07.615
